eclipse:
'Building target: VoltLED'
'Printing size:'
"E:\Tools\Eclipse_Sloeb_433\arduinoPlugin\packages\arduino\tools\avr-gcc\4.8.1-arduino5/bin/avr-size" -A "D:\Eclipse_Workspaces\sloeber4.3.1\VoltLED\Release/VoltLED.elf"
D:\Eclipse_Workspaces\sloeber4.3.1\VoltLED\Release/VoltLED.elf :
section size addr
.text 4498 0
.data 116 8388704
.bss 352 8388820
.comment 17 0
.debug_aranges 1264 0
.debug_info 32126 0
.debug_abbrev 6845 0
.debug_line 8240 0
.debug_frame 3548 0
.debug_str 9662 0
.debug_loc 22669 0
.debug_ranges 1368 0
Total 90705
'Finished building target: VoltLED'
15:02:40 Build Finished. 0 errors, 0 warnings. (took 13s.181ms)
Couldn't deeply cache core build: Rel:
Running normal build of the core...
Der Sketch verwendet 4614 Bytes (76%) des Programmspeicherplatzes. Das Maximum sind 6012 Bytes.
Globale Variablen verwenden 468 Bytes des dynamischen Speichers.
Description Resource Path Location Type
The type 'DigiUSBDevice' must implement the inherited pure virtual method 'Print::write' DigiUSB.cpp /VoltLED/libraries/DigisparkUSB line 214 Code Analysis Problem
